Hi,
I have a water heater I have to correct to make it within code I need to put a drip leg on the gas side of it, that's not the issue...the issue is with the part of the pressure relief valve.
I understand that the pipe needs to go down from that relief valve as you can see mine doesn't, it travels horizontal to it then 45's up and 45's again to be even with the top of the heater and back into the wall, well eventually when it goes through the back wall I'm sure it will. Any ideas on how I might do this. Code dictates that its not allowed to travel uphill because it could settle in horizontal area. It needs to go through the floor as well. One thing I need to check is under that floor it sits on I'm pretty sure it's the concrete foundation. It sits about 16 inches off the main foundation. I thought about abandoning that pipe altogether and cut into it and 90 it down into the floor but if there is concrete under that floor that poses another issue doesn't it? Any help would be appreciated
Thanks
Thanks
