1 - 20 of 36 Posts
Discussion Starter · #8 ·
DJ3, why would you not want to cut open? My original plan was to put it on my dolly and pull it up the stairs with my tractor. Once I strapped it to the dolly I could not even tip it. I am afraid it will be too heavy for my stairs too.
· flipping slumlord
Yes, It probably is the original then. For the record it was unhooked and one dated 2006 was the one I replaced. Not sure if it lasted from 56 to 06 or if there were others in between.
It was probably deemed too much a PITA to move. Now it's up to you.
Appliance type hand truck with straps, a couple strong guys...
and a six pack of cold beer in the driveway waiting.
I've cut up a water heater with a sawzall before, and it wasn't fun. It takes a LONG time and creates a LOT of noise (and uses up a lot of sawzall blades). It can be done though, and sometimes you just have to do what you have to do.
I didn't have an angle grinder at the time, but I'm guessing that would have been easier. Even better than that would have been a cutting torch. If you can find someone with a cutting torch, I'd try going that route.
Would very much like to see a wide angle photo of water heater.
Probably full of water.
" A pint's a pound the world around"
If full of water the heater will weigh 400 lbs. plus the weight of the heater itself.
Surely there is some piping through which you could determine if it is full of water.
Is your basement finished?
Are you ready for a big, heavy, messy job?
Watch out for what stays in the tank even after you empty it.
You would still need a helper to push up from the bottom.
Other than that, if you insist go ahead and report back, maybe with some pictures.
· A "Handy Husband"
A 3/8" drill bit and a few holes would determine that. Keep in mind that it might be heavy because it has inches of sediment at the bottom.
Be prepared to deal with the water if you do that. A floor drain would be ideal.
1 - 20 of 36 Posts
