1 - 9 of 9 Posts
New to the DIY. We flushed our electric water heater and replaced both elements and thermostats. We are refilling the tank and are not supposed to turn the power back on until is refilled. My question is: Should we be able hear the tank refilling? Upon initially starting to refill, we turned on another hot water valve... it sputtered but then started to run at a normal pressure. My mom is concerned because she can't hear it refilling, should we be able to hear it? Is there a way to test to make sure it is full, so we don't damge the new element?
· Long-Time DIYer
Open the farthest hot water tub faucet (no aerator to clog) and run it until all of the air is out and it's running a full water flow. Then open all hot water faucets to remove the last of the air in the lines. You can't necessarily hear the tank filling, but you're right, fill it with water before turning on the power or you will fry the element(s).
Mike
If you can shut off the water supply to the heater you could open the valve near the bottom of the heater and see if you get a good amount of water coming out. .
Psst! This is not a good test to prove that the tank is full enough to turn on the heat without damage.
Discussion Starter · #9 ·
Hallelujah, we have completed this fix. The water IS filling properly, and does fill very quietly and quickly. We actually had to drain it and refill it another two times because we had a small leak around the upper element. In turn we had to take the new element back to the store and exchange it, it was faulty. We have replaced the element and refilled again, no leaks...and we have now restored the hot water. I appreciate you all for your input and help. Thank you very much, WOO~HOO. :thumbup:
Erika
1 - 9 of 9 Posts
