The temp is set at about 130 degrees. It was at 140 and I turned it down to see if that helped (it did not). The expansion tank doesn't seem to have an adjustment on it. I installed it when I replaced the water heater last time, several years ago. It's rather small, a cylinder measuring eight inches in diameter and ten inches tall. It says on it "Pre-charge pressure 40 psi." Also "Water Heater Safety Tank." There's a nipple at the bottom. I'm ancient and technologically incapable of posting a picture. The tank is up high, about ten feet from the heater, and in a 3/4" copper line supplying the heater
