My water heater is rusted and weeping at the top. So, I call Lowes to do a detail on it to see if a tall could fit without much trouble because my current 40 gallon sits on a pedestal (wooden), and I wanted to get a 50 gallon (for resale value down the road); it's a 4-bedroom house.
The water lines come of the wall horizontally at 63", and a new heater is 61".
I'm guessing there would be some sideways travel of the flexible water lines to make room.
Here is the big question, because Lowes' original estimate of $299 to install jumped to $850 with ZERO extra construction work on the pipes or wall--just a plain install.
How difficult is it to re-drill a new drain line through the wall / brick of my house to the driveway? My heater is a 1st floor, laundry room heater.
If I lower the wooden pedestal the current heater sits on I cannot use the current drain line--too high. I'll have to cap it off on both ends and leave it.
It appears to just be a PVC pipe, coming off the drain line, right through the brick, with some mortar or cement around it to seal the gap.
Aside from the angle for draining smoothly is there anything other than a good masonry bit to get through the brick? And, of course, making sure I'm not hitting any other pipes / electrical lines along the way?
SO:
1. I'd prefer to keep the pedestal to avoid drilling a new drain. so, I'd need some guidance on the flexible water lines. I'm guessing as long as they are smooth curves and no kinks, it shouldn't matter.
2. If I have to drop the pedestal--best, safest, way to drill a drain line.
It's an old A O Smith 40Gallon heater with natural gas and an electric pilot.
I've changed a gas valve on my furnace, so I'm not worried about the precautions and tests with that.
SO:
