Hey all, this is my first post so I'd like to thank everyone in advance. I've already read through some great information. However, I can't seem to find anything that matches my situation.
Issue: Water is constantly running out of the T&P valve drain. And by constantly running, I mean a very steady stream (not drizzle). I haven't tested pressure or temperature yet, but will do that tonight.
What I have done: I turned the cold water supply off and opened a sink faucet to relieve the pressure and drop the water level a bit. This helps with the amount of water coming out of the T&P drain, but the water doesn't stop. Instead, the T&P drain goes from a steady stream to a drizzle and the inside water faucet constantly runs a light stream... even with the cold water supply to the water heater turned off!
Without testing pressure and temperature it sounds like I have a faulty cold water ball valve and possibly a faulty T&P valve.
Any thoughts?
Any thoughts?
