In my new house, I did some pipeline testing due to slow hot water flow in various places. This involved turning the mains on and off. One effect I noticed was that the CPVC pipes would buck violently and with a loud thud when I turned the mains water back on.
Had to help my parents with a valve replacement yesterday and noticed they have an expansion tank mounted horizontally (and perpendicular to the vertical mains run) just downstream from the mains valve. Not sure why.
Somewhere I read that an expansion tank eliminates the water hammer effect. I don't think I need this in normal operation--this only happens when I shut off the cold water and drain the pipes. Also there is no backflow preventer and the hot water expands like crazy (I know, I've run the tank without hot/cold hooked up and it pumped a ton of water out as it heated) but the pressure release valve doesn't open in any case, so I assume that the expanding water is just pushing back out the mains and thus I don't need an expansion tank for that purpose.
Are the banging pipes a problem? Or do I just ignore this as it only occurs if my pipes are empty (i.e. shut off mains, release pressure by running washing machine, turn mains back on)?
