Hello. We purchased our house about 7 years ago (house is now 32 years old) and it was very well kept. After the past 7 years, I'm now finding little things here and there that are starting to need some attention, so I may be on here quite a bit.
My first concern is the caulk at the top of the brick veneer on the front of my house. The brick veneer goes up approx 1/4 way up the front exterior wall. There is a gap between the top of the brick and the siding. The caulk that was used to seal this gap is cracked and water must be seeping in, as the inside baseboard on the interior side of the wall is pulling apart from the wall (great....). So i'll have some work to do there. Same issue is happening with the brick veneer and interior baseboard on the opposite side of our front door. But I figure the first step is sealing that gap up so no more water can get it.
My first question: should there be some sort of flashing here, or is the caulk just fine? I never noticed it because I never really paid attention to it until I started to look for the cause of the interior baseboard pulling away from the wall. Then I examined the exterior and found the cracked caulk.
Secondly, if some simple exterior caulk would do the job, what type would you recommend to adhere properly to both the brick and the wood siding?
