Need some help here.I had a new furnace installed about 3 years ago. Everything was fine until this winter. I had 2 new pvc lines ran from the furnace to the outside(fresh air and exhaust)? The problem(s) I am seeing now is that there is water dripping from one of the joints that runs through the garage(horizontal run), and I have water sitting on a joint that comes out of the unit(vertical joint) maybe 2 feet up from the unit itself. It is the same line, just dripping in 2 different spots. If you are looking at the unit,it is the line on the right side. Why is this happening and what needs to be done to correct it? Thanks in advance-Brad
