I have a detached garage with a finished upper. Currently no water supply or drain. Residence has lift station in basement that ejects all waste 200 feet to street with 15' head. I want to get a small bathroom in the upper of the garage. Is it acceptable to install a second station in garage lower that ejects to a wye tied into the main ejection line of the residence about 50' from the residence station? Of course a check valve ahead of the wye at the second station just like the check valve in the residence. Pump in second station would be slightly under-rated of that in the residence. Any comment appreciated.
· A "Handy Husband"
Depending on the distance and grades involved, I would be tempted to gravity feed from the garage to the existing ejector pump. Adding a 2nd pump doubles the maintenance.
That will probably be the route I take. The existing station is lower level and downhill from the garage. Dealing with Minnesota frost line, so some major digging along with electric and gas to cross...thanks for the comment!
· Owner
Oh I will.... Several years ago I managed a high pressure gas line, (thankfully a check valve about 200 feet away), with a backhoe. So when they say hand dig make sure you open it up a bit; can never be safe enough. Very fortunately, the only pain was in my wallet.
