hey guys,
heres some info on the reno im doing..
10ft x 7ft washroom 1954 2 story house canada
ive gutted the room down to the studs and joist.. fernaco'd cast iron to pvc 3in for toilet 1 1/2 for tub/sink drains.. cleaned up plumbing with pex.. got rid of knob and tube rewired electrical for gfci, fan and lite.. ran 14/2 to panel with 15 amp breaker for heated floors.. sistered and braced my 2x8's 16o.c. joist.. glued and screwed 3/4 plywood.. insulated and vapour barrier walls.. just boarded up walls with the blue board and in the middle of tape and mud..
questions i have is when i finish with the walls after prime/painting and start building my box for my drop in tub.. will it be a problem to put cement board on top of the painted walls and deck for the tub/shower area???.. afterwards modified thinset, kerdi then unmod with 6x6 porcelain tiles.. or can i go straight to kerdi then tile without the cement board??
for my floors i will be laying a 6in kerdi strip along the corners of the wall and floor.. heated mats on top of the plywood with modified thinset.. ditra with unmod.. then 13x13 porcelain with unmod again.. but before i lay the ditra and scratch it wont that damage my mat?? is the 6in kerdi a waste of time??
i think those are my main questions for now.. so any help would be gratefull
thanks
thanks
