1 - 7 of 7 Posts
I have the box in the photo that I want to connect to 1/2 CPVC water lines. The valve connections are machined inside to solder to copper. I want to use the outside threads and use a Metal/CPVC female adapter but not sure if these threads will work. Are they 1/2 inch pipe threads. The CPVC female adapter in
Photo seems to go on OK but I want to use one of those that has a factory Metal to CPVC connection and screws on like the plain CPVC female in photo.
Thanks
JM
Tom
Thanks. I was hoping to avoid soldering but like you said I don't like the brass into the plastic female adapter. I guess my main question is what kind of threads are those? If compatable with female 1/2 inch pipe, Lowes sells a metal female factory fused to a female CPVC.
Thanks
JM
Most of the ones I've seen are running threads, not IPS. I've seen people jam copper female adaptors on there and get them to seal. I wouldn't try it though. If you really really don't want to solder they make those boxes with PEX outlets. Get one and use a pex female adapter and a CPVC male adapter to convert over. You'd have to invest in a pex crimper though. I'd suggest just finding someone to make the sweat connections for you or getting what you need to do it and learning how.
Discussion Starter · #6 ·
That would be the safest thing to do. I can easily find someone to solder for me. I can gas weld and would feel confident to do it if I had the stuff needed but for two joints I will just get someone to do it for me.
Thanks
1 - 7 of 7 Posts
