Thanks in advance.
We are remodeling the laundry room which will include built ins over the washer and dryer as well as a countertop.
Currently the hot/cold/drain are all about 48 inches from the floor.
The top of the washer and dryer 40 inches from the floor.
My question is around the drainpipe, is there a minimum it can be from the top of the pipe (where you put the washer drain hose) to the floor?
I have read it is a minimum of 18" above the water line in the trap itself.
We are trying to lower all the connections so they are under the countertop in order to tile the wall above it.
The hot and cold are no problem, it is the trap/drain pipe length I want to make sure is right.
Thank you again
Thank you again
