Soak it in Sea Foam deep creep. After cleaning off as much as you can. The issue you may run into is wether or not your going to have a smooth enough surface to put a new seal onto. Also, chances are, his example isn’t exactly what you have. Is there a chance your missing a retaining pin, clip or screw?
