1 - 2 of 2 Posts
jackofall,master of some!
My washer is leaking during the spin cycle,where should I start? :huh: is it a seal on the bottom somewhere, or is it by my drain tube?...?.?.? thx Ax
if it is leaking near the door check the seal, if it is leaking slightly when spinning check the flexible hose which may have a small split in it.If it leaking alot then it may be best to remove the back and have a good look when the machine is spinning see if you can see anything.
1 - 2 of 2 Posts
