All,
I have a Kenmore clothes washer, model 110.92284100. You can see a diagram of it at http://www.searspartsdirect.com/model-number/11092284100/0582/0153200.html.
I have two problems, with the first probably causing the second. The first problem is that virtually all loads spin as if they are unbalanced. I laid the washer on its back, and noticed that two of the "Bracket Springs" are loose (part #2 on the Machine Base diagram http://www.searspartsdirect.com/model-part/11092284100/0582/0153200/00060721/00007.html).
Here're pics. This first set shows a wide angle view of the bracket spring on the left as you look into the base from the bottom, followed by a close-up:
Here're the pics of the bracket spring on the right as you look into the base from the bottom:
Both bracket springs are attached on one end to a "Washer Suspension Spring (part #3 on the Machine base diagram). I've studied the diagram, and for the life of me, I can't tell where the other end of the spring bracket is supposed to be attached. So, my first question is: where do I attach the other (non suspension spring end), and how do I attach it?
My second set of questions revolves around the outer plastic tub (no pun intended). I suspect that all the banging caused a leak in the seam where the tub bottom joins the tub walls. After the tub fills about 1/3, the seam starts to leak, until it gradually turns into Niagara Falls. I'm thinking of using JB PlasticWeld (which supposedly will adhere to virtually all plastics), or alternatively JB Plastic Bonder to repair the seam. You can find info on them at http://www.jbweld.com/collections/plastic-composite-pvc). Does this make sense? Would you recommend some other glue? Alternatively, should I use another approach (e.g., heat seal the seam)?
Or is trying to repair the tub a pipe dream, and I should simply replace it? If so, any thoughts on installing a used tub (roughly $85) versus a new tub (about $155)?
Finally, whatever y'all recommend, I need to get the old tub out. According to this video
, I need to use a spanner/tub nut wrench to remove the tub nut. I don't have one, and am reluctant to buy one, since I probably won't ever use it again. Is there another way to get the tub nut off? This video
suggests placing a screwdriver (or short chisel) in one of the tub nut's notches and using a hammer to loosen it. Is this a good idea? Would some other approach be better?
As always, your help is greatly appreciated!
Richard
Richard
