I need to know how to replace the drain pipe that is in the wall for my washer. The house was built in 1969 and the drain is too small to handle the large capacity washer. Could you please help?
yes, you could replace the pipe but before doing that, I'd give thought to the pipe being partially blocked, causing the water to back up. If you can, trace the pipe back to where it dumps into the main sewer, look for a clean out and take a look. built in 69' is a "newer" house.
The drain pipe must be at least 2 inches in diameter and the open end must be at least 18 inches above the trap. If not then it likely that a modern washing machine will cause it to overflow.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
