I bought new front load washer and dryer and wanted them on pedestals. But I also wanted to be able to roll out the washer/dryer rather than drag it across my new laundry-room floor. Since I could not buy exactly what I wanted, I decided to make it.
It could not just sit on casters. To get good stiffness, the pedestal structure has to sit directly on the floor. But if I need to service the washer/dryer, I can crank a wrench a few turns on a hex feature on the front of the pedestal, and 4" casters will pivot down, lifting the washer or dryer. Then the washer or dryer will pull straight out. I got a Magvent for the dryer duct connection.
I toyed with the idea of modifying the standard pedestals. Color would have matched better, although I found Formica high pressure laminate that is pretty darned close. But I am not sure modifying the factory pedestal would have even been possible, and my own pedestal is way stiffer anyways.
The cover piece is located with a couple of pins and kept in place with half a dozen neodymium magnets. I will have to make 4 pockets to bond to the top, to positively locate the feet of the washer and dryer.
