I had 16' double 6 insulated siding from a leading manufacturer installed 2 years ago. As you can see in the attached picture there is warping where the siding pieces meet. I was thinking of buying and replacing just the pieces where this warping occurs on the garage and house, thinking that maybe there was a manufacturing problem that was later corrected and doesn't affect the siding now. However, what I'm wondering is if this is a general problem with insulated siding, and should I instead replace the siding with a completely different one? Does having insulation glued directly to the siding create a temperate variance leading to an issue like this?
Sorry for image, for some reason it rotated it 90 degrees when uploading
