My new saw’s manual has the following warning:
WARNING! TO PREVENT SERIOUS INJURY: Only use a smooth rim, wet cutting, 10″ Blade rated to at least 4,000 RPM on this tool. Do not use a Blade that is too thick to allow Outer Flange to engage with the flats on the Spindle. Do not use a Blade that has openings, grooves, or teeth.
I need the saw to cut 2 3/8 pavers. Is there really a danger in using segmented blades? Don’t people do this all the time?
Thanks,
Steve
Thanks,
Steve
