I currently have a non-GFCI receptacle in our basement which our washing machine is plugged into, as well as other things from time to time. It's a few feet from a laundry utility sink. I want to replace it with a GFCI receptacle.
It's fed with some type of armored two-wire cable (no ground wire). The cable appears to have a bonding strip (see attached pic -- it's wound up around the armor outside the box). A plug-in receptacle tester indicates it's grounded.
When I install the GFCI, since it's a metal box, do I need to attach a ground wire between the box and the ground screw on the GFCI receptacle, or can it just use the supplied self-grounding clip (leaving nothing attached to the receptacle ground screw)? The metal box doesn't have a ground screw or a hole for one. I know I need to remove the paper insulating washers from the GFCI screws first.
Thanks.
Thanks.
