Greetings,
I installed under cabinet lights that I am sure are not to code... I would like to make it right. My first question, is it per code to contain an outlet and a switch in a duplex box?
Second question is, I've wired the switch into the GFI protected outlet beside it. I know you can't connect lights to this, but I've heard this switch can can control an outlet strip that the under cabinet lights plug into. Is that correct?
Thanks!
Thanks!
