Good afternoon... I'm about to start a light (heh... heh...
) kitchen remodel, and in thinking about the walls, I'm having an issue. I am almost finished a bathroom remodel in the same condo, and had to remove wallpaper in there, which is the same wallpaper still existing in the kitchen.
It was a horrible, horrible process to remove that stuff from the bathroom, and spent many hours sanding down the glue, only to find I was taking off the out layers of the drywall paper... after doing some research, I'm self-diagnosing the problem to be that the original builder put the glue right on the fresh drywall, with no primer... causing the two to bond.
The bathroom was a smaller surface area, and I've moved on from my initial
. As I begin to ponder the kitchen... a larger surface area covered with wallpaper... I'm left with several options.. and I'm wondering what ya'll would think is the best one:
A) Quite yer whining, Levi, and get in there and just do it (remove paper like bathroom), just be sure to use a really good primer/sealer when done before painting. My thoughts on this: time consuming, and I hate removing wallpaper.
B) Easy as pie: prime OVER existing wallpaper and paint.... (one issue here: in various fits of rage after thinking how on earth anyone could put up such ugly paper, I've ripped various non-uniform pieces off the wall at times, just leaving the glue/drywall bond stuff out in the open.. guess I could just rip the entire paper surface off - fairly easy actually - and prime that?)
C) Rip it to the studs and truley make it your own, Levi! While this is probably the way to get it down perfect how I want it, let's list off the cons: time consuming, I'm not the "best" at mudding, and I generally would prefer not to.
Thoughts? Experiences with A or B (or C)? Any discussion/feedback for me? :drink:
