1 - 11 of 11 Posts
Here is an odd one: Been asked to tile (6x6) over cement board on an exterior wall. No problem until they said they had painted the wallboard!
How should I prepare the board? Angle grinder with a sanding disk or wire disk? I plan on using unmodified thinset . . . is that the strongest?
Retired Moderator
Not so good----Grinder with a wire wheel to scuff well----unmodified with liquid additive is the strongest-Kerabond and Keralastic by Mepei is a good example.
A high quality modified thinset should do it.
Tile with Style
Yeah just scuff or sand any sheen off of it. Not a big deal painters are routinely ahead of us on jobsites and they always overspray. Don't use unmodified mortar, your situation needs latex modified mortar. All tile-concrete board installations use modified.
Tileguy
I want to see the answer to Bud's question.
Jaz
either keralastic or granirapid are WAAAAAY stronger than unmodified thinset
other than that, you can use a drywall sander if you really want to. just knock the sheen off. make sure you get any loose dust away in the process. as long as the paint is well-bonded, the mortar will be too.
i used to do a lot of tile on military bases, and in the name of things looking right for the people with the funny hats, a lot of mistakes like that were deliberately made all of the time.
Keralastic is a polymer reinforced thinset offered by mapei. They also sell the liquid latex that you add instead of water.
IT IS STRONG! if you have some spooge left over after setting a lot and you don't get it within 24 hours, it is almost impossible to break off with a 5 in 1
Tileguy
Yow I know that, :yes: I was trying to be gentle with you.:)
It wouldn't hurt for you to mention that Keralastic would be mixed with unmodified thinset to complete the thinset concoction.
man, i did that once on fort carson, and my boss freaked out! i tried to say, "don't worry about it, man" and he wouldn't have it.
i'm glad to hear someone else say it. i wish he was on this forum.
1 - 11 of 11 Posts
