I try to leave this forum for when I absolutely can't find an answer. I'm sure its out there on the net somewhere - just can't find it.
I'm about ready to start building a 10x20 gable shed. Where the wall sheathing meets the top plates - how should this be installed? I'll be birdsmouth cutting the 2x6 rafters, double top plates. Should the wall sheathing only cover the first top plate? Should I leave 1/4 or so of the lower top plate as the rafter continues down? (6/12 pitch). If it matters, the walls are going to be 105 1/2" (96" of 2x6, sill plate, two top plates). It has also been recommended to use PT plywood on the bottom 12" of the shed (slab is raised 6" above grade, but I'm in a snow area).
Any help/advice on this would be appreciated.
