1 - 8 of 8 Posts
Which is better to use batt insulation in a wall vs. blowing insulation in?
I have 2 exterior walls, 1 wall plaster is removed and when closing back up the walls I'll be installing batt.
On the 2nd wall, the plaster is still up and I'm debating adding a day to my project to rip it out and install batt on that wall too.
Thoughts?
Thanks!
Banned
Compacted blown would be the best route. Placing batts in the open walls, will just allow air movement. You really need to read the info at the Building Science website.
Dense-packed, either cellulose or fiberglass, is far better. Figerglass batts are the worst insulation made, unless perfectly installed (a rarity) and then it is still not great. It's OK, tho.
Registered User
Will you be caulking the stud/sheathing/plates joints before insulating?
Will you be air-sealing the drywall (ADA-- airtight drywall approach)?
Do you have any rigid foam board on the exterior?
Where are you located?
Gary
The studs/sheathing/plates are already up/in
don't know what air-sealing is...should i do this?
standard (1/2" or something) sheething then brick exterior
Live in PA
Gary
Really appreciate the insight...
Gary
I'm leaning towards blown in fiberglass insulation...any additional input?
Registered User
1 - 8 of 8 Posts
