Hello, I came across this forum looking for info about a project, but I think I need more specific help than I could find. The short version of my question is this: I'm walling in a raised bed with a stock tank pond in the middle, so what is the most cost-effective way of building the wall for someone with very little masonry experience?
The tank's dimensions are 63.25"L x 69"W x 25"H and I need the drain-side of the tank pressed closely to a wall to allow plumbing through it and into an adjoining bog filter; the other sides of the tank will have at least 1 foot of accessible land which will be filled in up to the lip of the tank so the resident turtle can have easy access. I've been doing a lot of research and I feel every time I've made a decision I soon find something else that casts doubt on it. My current plan involves a simple wall of mortared 16x8x8 cinder blocks (CMUs) reinforced with rebar and filled with gravel or cement.
I don't want to pour concrete for the footer (I'll likely need to deconstruct this in a few years), so I was looking into gravel based footers, but it seems that requires a sort of "moving" wall structure which can't happen without breaking the mortar. I've been looking into retaining walls and while the stack-and-lock types of stone might work, they seem much more expensive when considering coverage (it would also complicate running plumbing through the wall.) I don't need something that will last forever but I do need the wall to bear the soil and hold up my weight when I need to clean/maintenance the pond. I live in coastal North Carolina, so frost isn't much of a problem, but water drainage could be especially during the wet seasons (this is why I haven't really considered using lumber.) So is it possible to make this design work with cinder blocks or is there something else I should consider? I would appreciate any help you could give.
