1 - 10 of 10 Posts
Hello,
I've got my dining room primed and ready for paint (wallpaper removed) and my wife has her head set on picture frame style wainscoting (see image of a sample finished room). The idea is to make rectangles out of trim and nail them to the drywall, then paint everything.
1. How should I bond the corners of these frames? One How To suggested hot glue. Nailing is better, right?
2. How should I attach the frames to the wall? Finishing nails into drywall?
3. Should I caulk around the frames after mounting them? We get a lot of shrinkage in the winter here so I'm worried about cracks appearing.
4. Does it matter if I do this install during winter. Indoor humidity is about 35% right now.
Thanks!
Nailing it into just the drywalls not going to stay in place. Need to hit the studs.
I use some of this plus finish nails.
http://www.loctiteproducts.com/p/12...ng-&-Paneling-Clear-Construction-Adhesive.htm
Trim almost always will need some caulking because walls are never flat.
I use Tite bond II to glue the outside corners so they stay tight.
I paint the wall, and preprime and paint two cots on all the trim before even cutting so I only have to do a small amount of touch up painting.
Reactions: randlefactor
· journeyman carpenter
you also need caulking where wood touches drywall because there will be a thin black line anyway. the paint wont fill that hairline crack, if any shrinking occurs the paint will crack anyway.. the caulking eliminates that
you dont HAVE to nail to studs but it helps.. if thers nothing to nail to, glue and cross nailing will work also
Discussion Starter · #8 ·
hand drive said:
dividing up where they fit evenly spaced onto the wall and not hit receptacles is the trickiest part no doubt
You guys are right about the measurements being most important to get it all uniform and avoid outlets. Here's the finished room. So glad I'm finally done!! Thanks for everyone's tips!
1 - 10 of 10 Posts
