I removed a non-load-bearing wall and all went well. Next I needed to relocate the light switches. All 3 switches were on dimmers and operating correctly. I rewired everything, but now face the problem that only 1 of my 3 lights is working properly. Two of them appear like they are getting too much voltage. They are WAY brighter than they were before and when I move the dimmer setting all the way down, the brightness is cut in half, but still quite bright.
When I tie the switch directly to the light wiring, it does not have any power and the switch does not work. Leaving one wire tied to the switch and the second wire spliced to a hot wire and a wire from the switch is what is causing it to be a super high voltage. I have also tried switching which of the two wires is connected to hot and directly to the switch. There is no difference. Both situations lead to a bulb dangerously bright and a dimmer that only dims halfway at best.
Any suggestions what I might have done wrong?
Thank you.
-Steven Wolff
Thank you.
-Steven Wolff
