1 - 7 of 7 Posts
I have used at least 5 voltage drop calculators that I found online and have come up with different numbers.
What would you calculate the voltage drop / percentage for the following 2 scenarios?
4 outlets with the farthest 310 ft away.
20 amp breaker
THHN 10 GA
Same thing with THHN 8 GA
What is it your really trying to do?
Run power to an out building?
Good luck trying to connect a #10 wire to an outlet.
What is your 20 amp load at 310 ft ?
Most of the loads that you plug in are going to be 10 amps or less.
I don't usually leave things plugged into my yard receptacles. They are there so I can plug in one item when needed.
10 amps @ 310ft on #8, you are looking at about 4.8v drop or 4%. That right in line with the older 5% recommendation.
It will be less in the closer receptacles.
Unless you have a large known load out there or expect other people to be plugging in heavy loads and using them simultaneously with your use, I would be satisfied with it.
· Licensed Electrical Cont.
20 amp breaker
THHN 10 GA
You cannot calculate voltage drop without knowing the load (amperage).
You can reverse calculate it for what the maximum load could be.
Remember, countering voltage drop is a suggestion, NOT a code requirement.
Reactions: gregzoll
1 - 7 of 7 Posts
