When I'm not running any high load device in the house the voltage of outlets connected to different legs is about the same - 123 volts on one and 120 volts on the other.
When I run a high load device I'm noticing a bigger voltage difference between the two- For example with the toaster and coffee machine on I measure 131 volts on an outlet connected to the same leg (but not necessarily the same circuit) as the toaster and coffee machine and 112 volts on an outlet on the other leg. This is not a momentary difference- it remains the same until the load is turned off. The biggest difference I've noticed is 26 volts between the two legs- 134 volts vs 108 volts. Is this normal?
It is not circuit specific; I can recreate the issue between any circuit breakers as long as they are on separate legs (For example I see the same thing between outlets on circuit breakers 2 and 4 as I do with circuit breakers 3 and 5.)
Thanks in advance.
Thanks in advance.
