isn't this a violation?
i thought ANY outlets near water source had to be gfic?
tnkx
DM
tnkx
DM
Yes, I thought so, within a certain distance, for reasons of a water pipe ground and water being present.isn't this a violation?
tnkx
DM
No, there is no "within XXX distance to a water source". It may seem that way but that is not how the code is written.Yes, I thought so, within a certain distance, for reasons of a water pipe ground and water being present.
The water removes the current-limiting benefit of the resistance of dry skin, as do voltages >600v.
As it is new contruction, and if done properly and inspected- these outlets are highly likely to be GFCI protected- (probably didn't bother with the stickers!) I wired my kitchen like this- 2-20a circuits along the counter being fed by an initial GFCI for each- all the rest are regular outlets but protected by the first in the circuit.the one with the switches is gfci, so maybe they're strung from it? didn't think of that.
this is new const. btw. (not my place)
DM
The little stickers don't stay on long, at least not in a kitchen or bathroom, where, oh, they are most likely to be used, if used at all.As it is new contruction, and if done properly and inspected- these outlets are highly likely to be GFCI protected- (probably didn't bother with the stickers!) I wired my kitchen like this- 2-20a circuits along the counter being fed by an initial GFCI for each- all the rest are regular outlets but protected by the first in the circuit.
Why? That is an un-necessary expense.not my home, so i don't really care. i was just curious.
personally, i think i'd use individual gfci's for each.
That is more of a local building code. I have heard 4" or 6" depending on where I was.the outdoor balusters were also more than 4" spaces between.
THAT is wrong, no?
DM
I agree, WHY?personally, i think i'd use individual gfci's for each.
Four inch max spacing, at least here in Louisville.the outdoor balusters were also more than 4" spaces between.
THAT is wrong, no?
DM
unnecessary and wasteful? not to me.I agree, WHY?
Completely unnecessary and wasteful.
When I see this to me it screams DIY'er who didn't know what they were doing. :whistling2:
I have two in my garage, for the same reason. I wanted to make sure the whole circuit wouldn't go down if one tripped. In the basement, though, I have one GFCI protecting all the outlets in the basement office. I used the little stickers on them.if and when something trips, i want to be able to follow the cord back to the culprit. DM
Because 90% of the heads of little kids of a certain age will not go through this spacing.Four inch max spacing
Oh, they'll go. You just have to push them really hard...Because 90% of the heads of little kids of a certain age will not go through this spacing.
You bad, you bad. . .:laughing:Oh, they'll go. You just have to push them really hard...
