Hi guys,
I have an older condo (built in 1941) with a 200 sq. ft. porch that was added in the mid 1950's. The porch is built on a concrete slab and the current flooring is 9x9 VAT/VCT glued directly to the slab.
The current tiles are pretty grimy and many of them are coming loose from the slab, so I'd like to replace the whole floor with modern 12x12 vinyl tiles.
Since the tiles are probably asbestos, I really don't want to rip them out. Would it be possible to lay 1/4" plywood or other underlayment over the existing tiles, and then install the new tiles over this "new subfloor?"
If so, how would I ideally affix the plywood/underlayment to the existing floor?
Is there a better option?
Many thanks!
Sean
Many thanks!
Sean
