I'm building a new work shop. I've decided to use LP smartside with Vinyl soffits, held with F Channel. What is the best way to meet the smartside to the soffits? Should I intall the F Channel on top of a trim board and then the caulk the LP siding where it meets the trim board? Or, can I just attach the F channel directly on top of the siding without using a trim board?
· Banned
You could just use some molding that is mounted on top of the plank siding or rip down a piece of LP flat trim to create the ledge.
I don't care of a vinyl trim to me mounted on top of the LP if you can avoid it.
On the backside of the fascia, fine...but at the wall, I prefer something that is a bit more akin to the siding you are using.
