Trying to reno a 1950s house. Started tkaing off the aluminum siding only to find out...
There's a 1/2 foam board underneath the aluminum. Under that is the original cement shingle siding. We'd like to put new vinyl siding on.
My plan was to remove all the foam board. Then wrap the house with Tyvek. Then put on 1/2 furring strips. Then put the vinyl siding on. From research I've done, this seems like a legit plan. Not worried about taking off the foam board because the house has fiberglass insulation.
This is actually the second house I've run into cement shingle. First house was my own, and I took off the cement shingle and also the original cedar shingle underneath that. Rather than do all that work and have to rent a dumpster to get rid of all the shingles, I'm looking to do something different.
Posting because I wonder if anyone else has put vinyl siding over cement shingle. Any problems with my plan that you see? Any suggestions for easier ways to do it?
