1 - 20 of 24 Posts
I'm hoping someone can give me advise asap. I hired a contractor to install certainteed vinyl siding on my house. I showed him a house nearby and said basically that this is what i want my house to look like. Well..they started the siding, i went to work, and when i got home I was very very pissed at what I saw. The house looks like a billboard for j channel. Its everywhere. Around all the doors and windows, around the base of the house. It looks awful. I called immediately and complained. I said my neighbors house has no j channel and thats what i said I wanted my house to look like. I was told that the other house has newer windows and that they used lineals and lineals cant be used on my windows. Is it true that lineals cant be used on older windows? I'm guessing my windows are around 10yrs old. They are anderson double hung. Also if I cant use lineals, is there any other way to avoid the ugly look of j channels? Please help me on this as I have to deal with the contractor first thing in the morning.
Thanks!!!
I dont have a contract per say. There were several back and forth emails outlining the job in which i stated i wanted lineals. He said that i cant use lineals on my windows because they are wood anderson double hung with brick mould. I then had him look at my neighbors windows and he said he could trim mine like theirs are which looks like aluminum coil framing out the window in about a 31/2 " frame but no j channel showing. Now the job is 1/2 done and it is the worst thing ive ever seen. The back of the house has j channel everywhere. The windows look nothing like my neighbors and his excuse now is that my neighbors windows have a built in j channel. There was no mention of this before the job was started. My windows have aluminum surrounded by j channel. It looks like a job done in 1985. I'm so pissed off. The only thing i have going for me is that i have not paid a dime towards the job yet. I have a feeling that this is going to get ugly because i dont plan on paying until the job is done right.
I guess I should have had a contract although the emails outlined the whole job. I just figured this guy would do the right thing. Either way I haven't paid for the job yet. I was also wondering if theres different grades of the aluminum coil used to wrap the windows. What was used on my houses looks like a dingy white. Are there better grades where the color is brighter?
Administrator
It’s not to late for a contract. Don’t let the job continue until you both agree on what’s to be done and for how much money and get it in writing. Take the day off work if you must to get this resolved. Stay calm be professional yet civil.
Discussion Starter · #9 ·
I just got off the phone with the contractor. I also called certainteed to make sure lineals could be used on all applications..they said yes they can. So i called the contractor and asked why I was told that I couldnt use them. He said that its not proper to use them on my type of windows and that certainteed is just trying to push their products. I then told him that I spoke to two other contractors that said I could use them and his story changed to " my foreman who has been doing siding jobs for years told me that you cant use them". I'm now waiting for him to call me back as the steam is coming from my ears
Discussion Starter · #10 ·
Just got off the phone with the contractor. He is now saying that in order to use lineals on my windows they would need to cut off the brick mold. This would ruin the integrity of my windows. That is why lineals can't be used on my house. Does this make any sense? I'm lost on this
Discussion Starter · #11 ·
Kwik...the hardest part is remaining calm..but thanks for your advise. When i start to feel like i'm being taken advantage of I lose my temper fairly quick. Thanks for bringing that up as it is a valid point
Administrator
I don’t know that your being taken advantage of. I’m sure you contractor would just assume be working on your house today than ordering more materials. It’s pretty obvious you two didn’t have a “meeting of the minds” which is a contract, verbal or otherwise. This is why we write there things down and sign them.
Brick mold is window trim, lineals are window trim, to have lineals around brick mold would be double trim and look retarded IMO, it‘s one or the other.
You do know the lineals cost quite a bit more than the J which is something I’m sure the two of you need to work out.
Just be sure he comes back with a contract and "all" of your concerns are addressed before you go any further or this could turn into a way bigger mess.
Discussion Starter · #13 ·
I think that by saying i couldnt use the lineals the contractor was trying to lower his costs. The j channel looks absolutely horrible and cheap. Had I known this is what he was going to do I would have never agreed to it. His solution now is to re trim the windows with aluminum so that the j channel can't be seen.What is the correct way to do this? Does this sound like a good solution or is he just trying to get away with an easy fix? Will the vinyl siding have to be removed from around the windows in order for him to do what he's saying? I know I'm asking a lot of questions. I really appreciate the help
KemoSabe
I've installed well into the thousands of Andersen windows over the last 25 years and have never seen one with a brickmold either factory installed or field installed. I'd love to see a picture of what it is you have going on over there.:huh:
Discussion Starter · #16 ·
Here's a picture of the garage and one window. I'm curious how this is going to be fixed. If they take aluminum and go over what is there now with a bigger piece and nail it on top I have a feeling that it will eventually look like crap and is probably not the right way to fix this. What is the right way to fix this? I'm so pissed that I'm even involved in this situation. Help
Remodeling Contractor
Thanks!!!
There is a way to avoid all the J on the trim.A good brake guy could have bent
the J into a window trim to mimic the lineal look you wanted.
Kind of late now,but at least it looks like the installer is doing a pretty neat job otherwise.
He can still re-wrap the windows using coil stock to give you the J-less look,
although I'd question how watertight that trim job would be.
Have him do one to see how it looks.
Another concern would be where any water goes that enters that J.It could be
dumping behind the siding if he didn't divert it correctly near the bottom of the
windows.
Here's a pic of a trim with the J built in on an Andersen unit.
1 - 20 of 24 Posts
