hi - i have a corner of the house that has been leaking inside. It is right off of a sunroom and next to the outside door. Upon investigation i found out that the person who installed it never put any house wrap underneath. To make matters worse, the room is pretty much at or below the level of the ground outside which slopes down towards the house. I completely re-routed a brick pathway to grade away from the house and to the side down to the street and was able to get some of the vinyl off of the area's lower section (approx. 15inches or so) and put in a stick on flashing. These things helped for many months so i thought all was good until i had to replace the sill boards inside the room which had been rotted from years of leaks this weekend. Last night we had rain and (of course) the corner in the room leaked. I assume all the pounding of the joists, etc. unseated a caulked/ sealed joint. Aside from pulling off all of the vinyl siding and applying housewrap is there any other solution or idea anyone has? I think rain is flowing down the vinyl and not wicking away but sitting or finding it's way under all the flashing and caulking. Winter is coming and the sunroom is completely gutted and not in use but there is nothing worse than seeing water inside your house
