If the limit part of the switch is okay but it's not bringing on the fan, you can set the t-stat to bring the fan on with a call for heat as a temporary measure.
I've read about heat exchanger problems with the early pulses but they apparently were otherwise solid. lennox was ahead of it's time; they had two-speed, high-seer a/c units in the 80s as well which must have been hell to work on.
