I have an existing 50amp breaker and 3 prong plug and would like to connect a vintage GE electric range.
I do not know the amperage of the vintage range, and I need to replace the plug, as it is weathered.
Is it okay to replace the (unknown amp) plug with a 3 prong, 50amp plug and connect it to the 50 amp breaker?
What would happen if the range is actually 30amps (or 35, or 40...) - will the oversized plug or oversized breaker have consequences??
The GE Range model #:1J367M
Disrespectful to dirt
GE recommends a 35 amp cord, which you will not find easily.
A 40 amp cord will work fine, as will a 50 amp cord. The only consequences will be a little wasted money and possibly a bit of extra time wrangling the new cord in place. Oversized cords are not harmful, it's the undersized ones which overheat and cause problems.
I'd check the receptacle wiring. If you have 3 conductor plus ground, I'd change it to a 4 prong plug and put a 4 prong cord on the stove.
If it's an old range with no 120 V part (clock, timer, lights), then it is completely unnecessary to use a 4-prong cord. Even if it has, using a 3-prong cord is acceptable. Oversized cords and plugs are always fine.
