Problem: removing vinyl tile glue
Notes: Top layer was vinyl sheet glued down (approx 1995), and has been removed. Bottom layer is like commercial grade vinyl glue down tiles (1988). Each tile is taking me about 4 minutes to remove, and the glue is very very sticky. I've tried removing tiles faster using a heat gun and floor scraper, but the best way I've found is with a pry bar and slowly working the tile up. Many are breaking into 1" pieces. Vinyl needed to be removed to repair subfloor due to an old leak from prior owner not putting the washer drain all the way in.
What I need help with: The glue residue is extremely sticky and pretty low profile- my shoes get stuck to it, if I set a tile down on it the tile get reattached. I plan to put wood look interlocking (floating) vinyl planks down.
-Do I need to remove the current glue?
-How do I remove the current glue? I've tried covering an area with a very hot wash cloth and then scraping and that did nothing. I used a heat gun which softened the glue slightly but really not much improvement. I've tried cleaning the glue off my pry bar with "paintbrush cleaner" and that did about as much as the heat gun. Any tips?
