Hello,
New to this forum, looks like a good place to find info....
I;m a maintenance supervisor for a couple of apartment properties in AZ.
Our team tackles as many challenges as possible-to save money, but mostly to gain knowledge in as many areas as possible.
Our weakest area has to be within the hvac field....
One of our rooftop a/c units is showing very high pressure on the high side-350-400psi....Low side at 70...
I don't have the unit model no. at hand...
WeatherKing(Man. by RUUD)
1.5 ton,12 seer
All units(99 of them) are now out of warranty....
Compressors starting to go. Daily temps now regularly 95-110 F.
This particular unit is running cold initially, reaching 49 deg.F at the closest vent to the evap/handler.
But within 10-15 minutes of continuos running the temp starts to raise until eventually room temp. air is just circulating.
The capacitor was replaced and a hard start kit was installed and it seemed to be cycling/cooling fine up until I left for the day 2-3 hrs later.
But what could cause such high pressure on the high side, and the low side seems to be within range??
1.5 ton,12 seer
