I've been reading here about vetical float switches vs tethered on a sump pump - the concensus seems to be that the vertical switches are better 'cause they're more reliable.
I installed my backup pump this weekend - old system had a tether - ran for about 3 years - switched on @ 12" and off @ 4" - the new pump has vertical switch - on @ 8" and off at @4" - about half the travel of the tethered switch.
I take it the new pump will cycle roughly twice as often as the old - so I'm wondering if this is a good trade-off (better quality switch, but will I burn out the new pump sooner?)
Right now (wet spring weather, last of the snow melting away) the old pump cycles about 2 or 3 times an hour. In a heavy rain it can run every 5-10 minutes. Thinking the new pump is going to get a workout in the next heavy weather. Should i be really worried?
New pump is a Diamond (Wisconsin) - cast iron w/ stainless steel motor housing - 3 year warranty. Not the cheapest but not the best.
