1 - 11 of 11 Posts
Hi Folks
First post here so bare with if I'm unclear at any point. Bought my first house back in 2015 and, slowly but surely, am doing my best to fix up any deficiencies I come across. The house was built in 1976 and has a mansard roof (see pic 1). Worth noting I live in St.John's, Newfoundland. It gets crazy windy here!
In a nutshell, my question has to do with whether my soffit vents are allowing enough air through OR whether my baffles are installed properly. Here's the backstory: When we bought the house, the inspection discovered there was inadequate insulation (fibreglass batts and blown in cellulose over top - not much) and inadequate ventilation in the attic. The ventilation issues were evidenced by stained roof sheeting. It was determined this was likely cause by the fact the batts were stuffed into the roof perimeter, there were no baffles, and a piece of cardboard was acting as the attic hatch. There were vinyl soffit vents installed on the exterior and 5 vents on the roof so I was satisfied the stuffed batts/lack of baffles was the problem. To solve said problem, I hired someone to top up the insulation and install baffles. I put in a properly sealed hatch.
Flash forward to current day. I'm getting ready to get my roof redone as the shingles have seen better days (another sign of poor venting) and wanted to ensure my venting problems were solved. Now I hadn't actually crawled into the attic until now and upon doing so realized its very warm in there, possibly too warm. Furthermore, I couldn't feel a draft when I put my hand up to the baffle. Is this normal? If not, perhaps the guy who put the baffles in didn't dislodge the batts enough.
The only other thing I can think of is that maybe the plywood behind the vinyl soffit vents on the exterior don't have vent notches cut out of them. Instead of tearing down my vents on the outside to confirm this I realized I have a picture of the inside of the wall portion of my mansard roof which can confirm it. Reason being I had a problem with my chimney (long story) and had to replace a section of wall in the master bedroom. In attached pic 2 you can see a section of the wall portion of my mansard roof immediately adjacent the chimney. In the bottom right corner you can see a small circular portion cut out of the plywood which allows air through from the vent below it - pic 3. It looks pretty small compared to the vent below imo. Does this seem sufficient to allow proper air flow from the vent below it? Thoughts? Thanks in advance!
retired framer
No the holes should have been much bigger on a normal house we would remove that material, but it might be structural in your house.
The other thing to check and some have found is no common space from that cavity to the attic so baffles don't help.
So you're saying in BC you would remove the plywood behind the soffits vents altogether and allow the wind to blow up the wall cavity portion of the mansard roof where it would then be channeled through the baffles and into the roof portion/out the roof vents? I imagine you get some strong winds there but I can't help but think the plywood serves some structural purpose here.
Good point about checking the opening between the wall cavity and the roof portion - I'll have to check it out. I just assumed when the fella put in baffles he would have told me that. But you know what they say about assumptions........
retired framer
I haven't worked on a mansard so not familiar with the structure it looks like that plywood could be flooring but I don't know that but bigger hole should have been cut.
The plus here tho is that vented soffet is easy to work with so it can be re and re fairly easily .
Baffles go from the attic into the over hang and as you have no over hang???
Well the way I see it the whole shingled wall portion of my roof is the overhang. So air should shoot through the soffit vents, up the wall portion, and though the baffles into the attic. Thought I'd attach this pic to help clarify.
Basically the picture above (of the wall cavity portion of my mansard roof) is on the other side of the shingles to the right of the window. Normally the homeowner would never see this but I had access to it as I had to rip open the wall behind the chimney in the master bedroom due to water damage.
I think I will check that the attic and the wall portion of my roof are not blocked first. If they aren't blocked I will have to take down the soffit vents on the outside and cut bigger holes in the plywood to allow air through. The only reason I'm hesitant to cut bigger holes is I feel like more air flowing through the wall portion will make the 2nd story of my house colder. That and the fact we regularly get 80/90 kph gusts here.
Anyways, I'm likely not going to go up in the attic until we get a really cool day, so might be a few weeks left. I'll let you know what I find out!
retired framer
If that wall has a top plate and the rafters sit on that?????????
It could be built with venting in mind, in the attic you would hope that the wall continues above the ceiling.
Venting is 98% for ice dam problem.:smile: It doesn't keep the space cooler and doesn't help with shingle life. For your kind of roof, do you get ice dam? If you do, you'd see lot of stains on 1st floor ceiling, being in your area. If you have water stains, where? I would expect more problems with flat roof above and flashing around the windows. Also, your rafter is also your wall. Venting the wall, even if insulated, would keep it cold.
Some roofing pros may tell you, but dense packing the bay space may work better. You'd remove the soffit vents, sheath and air seal, then blow in dense pack newspaper insulation (name?). Remove ridge vent, air seal and reroof.
Discussion Starter · #8 ·
Sorry about the slow response, I was out of town the last few days. Interesting point about venting not helping with keeping the space cooler. I would've thought lack of air flow through the soffits would keep the attic warmer and, because the attic is warmer, shingle life would be lessened.
As for your ice dam question, no, we don't have an issue with ice dams. So perhaps ventilation isn't something I have an issue with. Maybe the stained sheeting that I see in the attic is due entirely to the fact that the piece of cardboard we had covering our attic hatch was letting a lot of warm air up there which was creating condensation and over time it created discolouration. Also I forgot to mention below the 2 bathroom fans were also venting hot air into the attic (which I corrected) so this might've contributed as well.
Back to my original post/question, I couldn't feel a draft when I put my hand up to the baffle. Is this normal? It wasn't a particularly windy day outside but I still thought you would feel some sort of draft even on a calm day
Ventilation is also necessary to remove any moisture that seeps into the attic via air leakage or diffusion. The staining on the inside, as you suspect, is probably due to condensation and a leaky attic hatch would be a major contributor.
As for shingle life the Florida State University has done a lot of work researching that issue, specifically in relation to unvented attics where the temp rise has no relief from venting below. As it turns out, the resulting temp rise is within the limits the shingles can handle and they were testing in Florida. Here's their link.
http://www.fsec.ucf.edu/en/publications/pdf/FSEC-CR-1496-05.pdf
Bud
Reactions: JiggsDinner
Discussion Starter · #11 ·
Thanks for the feedback Nealtw and Bud9051! I plan on double checking that the attic is properly air sealed (I haven't checked around light fixtures and bathroom vents) but am thinking my ventilation isn't as bad as originally thought. Will reply back next time I'm up there on my findings :)
1 - 11 of 11 Posts
