I am completing an upstairs addition in Houston, Texas, that includes a toilet, shower, sink, and a bar sink. The drain lines were previously installed. It consists of a 3" stack to the 2nd floor. There is then a horizontal 3" line that has the toilet, then the sink, and then the bar sink. A 1-1/2" line connects the shower to the fitting at the junction of the 3" horizontal and vertical line. The shower trap is 2' from the stack. The toilet flange is 5' from the stack. The sink is 8' from the stack. The bar sink is 15' from the stack.
There is an existing 1-1/2" vent thru the roof for a half bath (toilet & sink) on the first floor directly below this bathroom. It is at the extreme end away from the septic system of the existing drain system on the first floor.
When I continue the stack up to the roof, are the toilet & shower close enough that they don't require an additional vent line? I plan on connecting the two 1-1/2" sink vents to that stack also.
If I decided to use the existing location of the vent thru the roof for the new stack vent and tie that old 1-1/2" vent into the stack vent in the attic, what is the smallest size I can make the stack vent? Can it be 1-1/2" since the drain on the first floor at that location is probably still 3" and the vent would be half the drain size?
