What area of the vent pipe usually gives way to leaking 1st(after many years )?
H hidden1 · Registered Joined Feb 3, 2008 · 431 Posts Discussion Starter • #1 • Nov 17, 2012 What area of the vent pipe usually gives way to leaking 1st(after many years )?
M mae-ling · Registered Joined Dec 9, 2011 · 2,695 Posts #2 • Nov 17, 2012 flashing. either where the flashing and pipe meet or the flashing and the roof.
J joecaption · Registered Joined Nov 30, 2011 · 37,261 Posts #3 • Nov 17, 2012 Why you asking? http://www.bing.com/images/search?q...D472BCC1A80BC5CA49CB69E3032204F11C21E&first=1
Windows on Wash · Exterior Construction Joined Aug 30, 2011 · 27,704 Posts #4 • Nov 17, 2012 Most often times the boot becomes UV degraded and breaks down. That is an overwhelming majority of the failures.
H hidden1 · Registered Joined Feb 3, 2008 · 431 Posts Discussion Starter • #5 • Nov 17, 2012 (Edited) Just sealed mine and wanted to know. Thanks
J joecaption · Registered Joined Nov 30, 2011 · 37,261 Posts #6 • Nov 17, 2012 Sealed it Hope you do not mean you used something like roofing tar or silicone on it. Not going to work!!
H hidden1 · Registered Joined Feb 3, 2008 · 431 Posts Discussion Starter • #7 • Nov 17, 2012 over the nails at the bottom of it
Windows on Wash · Exterior Construction Joined Aug 30, 2011 · 27,704 Posts #8 • Nov 18, 2012 hidden1 said: over the nails at the bottom of it Click to expand... That is fine but that is not where 99.99% of the leaks on vent boots come from.
