1 - 9 of 9 Posts
I am thinking on using a dryer vent hose for my bathroom exhaust fan seen here
https://imgur.com/L3ZYSjS
But i am not sure if that is a hard outer casing or soft and if it would be a good product to use in my attic. It's about 25 ft long.
Or would i be better off using something like this:
https://imgur.com/LOnXhl1
They are both around the same price so that is not the issue. I just want something that will last as long as possible.
Your thoughts ?
Should be insulated. Or else it can sweat badly in certain conditions.
Yup, I know first hand. When my house was built they ran two fan hoses into a Y and one up to the roof. The Y was metal and it sweated and water dripped onto the ceiling in the master bedroom. Had to touch up a freshly painted ceiling.
Discussion Starter #4
Can you guys recommend some that are insulated and are no shorter than 20 ft long and they are 4 in in diameter? or would i be better off getting something 5 in in diameter. Your opinions are greatly appreciated. Pricing around $30 and preferably not more.
TIA
I’m not certain of what you mean. Inside and outside of what?
The links you provided are regular drier hose. Not insulated at all.
Discussion Starter #8
How do i tell which ones are then? As long as it says it is insulated in the description?
Insulated flexible duct looks much different then standard drier hose.
It has a plastic main duct wrapped in fiberglass which is then wrapped in a plastic outer layer. It’ll be what you want to vent an exhaust fan in an attic.
Or use hard pipe and insulate it after your done.
1 - 9 of 9 Posts
