Hi bought a bi-metal and carbide 4" hole saw for a dryer vent in a condo. I went through 2" of wood then hit the roof paper vapor barrier. I changed to a carbide bit and drilled a 1/2" quickly then it seemed to stop cutting. I tried running on the hammer setting of my drill but that allowed only another 1/8". I thought something was wrong, but I've never used a hole saw in stucco. I see inside the wall that I'm still in cement/stucco, anyone have any ideas?
Here are some pics. first is the carbide bit the second is the hole sorry it's a bit odd looking the outer material was 2" wood then a ligher colored cement like material as you can see the pilot hole and the material I cut how ever if you look at the groove it almost looks like there is a mesh wire but can't tell if it is that or the grooves from the blade.
