Hi there! I need to make some repairs to some loose bricks in an old non-structural interior wall - it's at least 100 years old. Many of the bricks have extensive spalling, while many are still ship-shape. As I understand it I need to use an old mortar mix as a modern one will cause the soft bricks to implode.
The mix suggestions I've found online vary. Some mixes call for just lime and sand, others call for some cement. Then there is no consensus on ratios.
Sorry for the multiple questions. Thanks in advance for any help!
- Can someone chime in on the correct ratio of lime, sand and water?
- Should any portland cement be added?
- Is "Hydrated Lime" what I want?
- Is the sand you would put in a kid's sandpit sufficient, or is there a special sand I need?
- What is the ideal consistency? I also found no consensus on this.
