1 - 16 of 16 Posts
· Premium Member
soaker tub and backsplash, kitchen backsplash, Var fixes around the house.
Hi,
Will getting a variable speed handler on a 1.5 to 2 ton split heatpump system make a good bit of difference in terms of pulling humidity out of the air and air quality? I do plan on putting in a uv light on the coils if that makes a difference...
Especially if the condenser is only single stage?
Still in analysis paralysis.
· Hvac Pro
Variable speed air handlers if they have a ECM Variable speed motor are good for constant air circulation as the motor uses a LOT less power than a fixed speed PSC motor. Plus you can run them on continuous at a much lower speed which is quieter and less drafty.
They won't remove much more moisture than a properly setup multispeed motor with a single stage unit. You can tweak the airspeed +/ 5% on them and get a bit better humidity removal but it is not a huge improvement considering the extra cost of the motor.
ECM motors have ball bearings and can run longer w/o seizing up than PSC motors but they cost 4x as much to buy and are pretty expensive.
· Premium Member
Most new systems have ECM dont they?
Would replacing a multi-speed ECM be much more expensive than a Variable speed ECM?
· Hvac Pro
The X13 are 4 speed ECM motors but a true variable speed has infinite speeds ( almost ).
The variable speed ECM have a lot more electronics and expensive parts vs a simple 4 speed X13. That drives up the cost.
The variable speed ECM is the most expensive followed by the X13 fixed speed ECM followed by the old school PSC which are starting to go obsolete on new units.
· Premium Member
So then, if I do not have money to burn, Multispeed ECM (I have only seen 3 and 5 speeds... that I know of) might be a better option in case one breaks...
I know this is only partially related (Humidity) I know it is more complicated than this...
Since I am 1100 sq ft.. that is in the middle for 1.5 and 2 ton compressors.
Most are saying do the 2 ton. If I had a 2 stage, would that help pull more humidity out of the air? Running at +66% sounds like it would run like a 1.33 ton compressor? Would that even work with a multispeed handler?
The variable speed motors seem to be available for @300?
My area . Virginia .
For that size the question would be 2 or 2 /12 ton for some.
· In Loving Memory
A VS blower will help remove a lot more humidity/moisture than any multispeed motor will.
· Premium Member
Discussion Starter · #8 ·
Thanks! Just to be sure: is this true for pairing it with a single stage -
as well as a 2 stage compressor??? :rockon:
· In Loving Memory
Yes.
With a single stage, the blower can be set up to move a very low amount of air for the first 30 seconds, and then move only 87% of normal air volume for 7.5 minutes. To aid in moisture removal.
It can also be set up to run slower when ever the humidity is higher than set point of the thermostat.
· Hvac Pro
It comes down to where you live and what your needs are. If you live in hot humid Florida then you want the most humidity removal so a variable speed ( the other I call X13 ) does a better job but the upfront cost is higher ( usually around $500 Cdn ).
I don't know how many speeds each brand uses and the X13 has 5 speed taps but it depends on the brand ( Lennox etc ) as to how many are used for different functions. I call them 4 speed as I am a furnace guy and PSC motors are usually all 4 speed.
The cost to replace a PSC motor by a dealer is $300-500, X13 $700-800., Variable speed ECM they start at $1000 and go up and you have to buy it from Lennox or Carrier etc as they are programmed to match their equipment.
The slow ramp up is kind of a waste, when the humidity is not too high it's better to go full cfm right away.
It's better to just slow on demand with a humidistat.
· Premium Member
Discussion Starter · #12 · (Edited)
This was a duplicate message? Glitched.
· Premium Member
Discussion Starter · #13 ·
That is amazing because the entire handler with the coil and some even with the heater coils are only one or two hundred more than that. (variable speed)
parts in general are super expensive.
the module for the variable speed can be replaced separately from the motor at a much lower cost.
the prices listed above are what the contractor charges, it's a lot cheaper if you do the job yourself especially for the psc and x-13 type motor. variable is tricker to diy due to the proprietary programming but i believe there is a generic one out which takes the programming retained on the board.
· Hvac Pro
Yeah that is why we don't replace many compressors in AC units after their 10 yr warranty is over.
The labor and cost of the compressor etc is more than installing a new unit.
The prices I quoted are flat rate pricing which most larger companies use but that pricing is very common with some smaller ones also. My dealer cost on a ECM non X13 is pretty high.
· In Loving Memory
VS blower motors are very reliable, and seldom go out/die on their own. Most often, it is killed by under sized duct work. Often, only the module needs to be replaced, but even it is not cheap, around 400 bucks.
X13s/ECMs are the next best thing to VS blowers, but not as good.
1 - 16 of 16 Posts
