I painted cutout pieces for an outdoor sign I am making. I put a coat of primer and 2 coats of water based exterior paint on so far. I am planning to apply some Varathane Spar Urethane, clear water based for added protection. The can reccomends 4 coats, but thats on bare wood. Being that its painted, do I still need 4 coats or would like 2 work? Thanks
It's about the same since if you ignore the water seal applied already, this question is moot.
Water seal may be combo of kinds of silicone and kinds of wax. Problem is it may not wash off, in the paint so to speak. If you apply water base or oil base clear seal, the seal may end up with spots (like water spots) or alligatoring.
If you must, try non amber shellac. Spray, not brush on. Alcohol in shellac will melt (smear) water based paint. Shellac may stick to water seal. No idea if it will work since shellac is weak to outside conditions, esp water. Vinegar wipe may remove silicone but also don't know what vinegar will do to acrylic paint. Search and ask further.
I found out you can put the spar urethane over painted wood, provided the paint is dried well. Thats for either oil or water based. These painted and clear coated pieces will get glued to the cedar backing that has the waterseal on it. Yes the adhesive will still adhere to the cedar as I tested it first, plus I am also using brad nails.
I asked the other question about putting the spar urethane over the waterseal because I was thinking about putting the sign all together and coating with spar urethane all at once. Instead, I coated all of the painted parts first because I dont know how the spar urethane will react to the waterseal, if it will work good or peel off in a short time. 2 separate questions for 2 different things. I will do a test board here for future reference so I know. Being my first time doing this, I had no idea what works with what.
